My Box of Things Sale, R34, 180sx, V35, RB20, SR, CA. Located in Tascott NSW 2250
Willing to Post, Pictures Available, Msg 04049212eight Seven or PM
R34 Stuff
R34 standard filter box bottom half only $10
R34 Standard Arms $Free
R34 GTT stockies $150
R34 Dash $50
R34 GTT Spoiler $80
R34 Coupe doors $50 each
R34 interior trim pieces $20 each
R34 Viscous Diff Centre $50
R34 Standard Gauges $60
R34 Rear Hicas Module $40
180sx Stuff
Sr/Ca gear stick/knob/plate $10
CA Manifold $10
180sx Black tail lights $100
180sx headlights $50
180sx pig nose front bumper $150
180sx rear bumper $50
Ca/Sr non abs tailshaft $50
Sr 20 carbon pod filter Cover $20
Ca18 a/c compressor $20
5 Bolt Dump pipe into 3 bolt $40
S14 Standard Fuel Pump Assembly $5
Rb20 engine complete in bits all parts available $125 for the lot
V35 Stuff
V35 Front Bar $250
V35 Rear Bar $250
Universal Parts
1x 18x8 +42 and 1x 18x9 +33 PDW Replay no tyres $20 each
New Nos Pod filter $5
Malpassi FPR $20
Intercooler 600x300x76 3” in/out $100
Hi there,
I'm after the following if you have any?
- GTR front lip
- GTR wing (must be genuine, 3pc wing. not fibreglass shit, got one alrdy!)
- RB20 coilpack cover. Prefer factory ones but will consider tidy aftermarket ones that cops will take nicely to!
Located south east Victoria, so will require shipping.
Sorry only have 5 RB20 coilpacks as I dropped one and the plug part broke so I just put it in my bin. coilpacks work just fine but I've upgraded to splitfires.
5 Coilpacks $30
  • 9 months later...
  • 3 weeks later...
My Box of Things Sale, R34, 180sx, RB20, RB25, S15, R32, SR, CA. Located in Tascott NSW 2250
R34 Stuff
R34 Dash $50
R34 GTT Spoiler $80
R34 Stock Turbo Manifold $30
R34 5 Bolt Drive Shafts $100
R34 5 Bolt Diff Half Shafts $50
180sx Stuff
CA Manifold $10
5 Bolt Stainless Dump pipe into 3 bolt $40
S15 Front Brake Rotors Machined and Sealed $50
R32 AWD RB20DET ECU $50
Updated 28/03/2016
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
