My Box of Things Sale, R34, 180sx, V35, RB20, SR, CA. Located in Tascott NSW 2250
Willing to Post, Pictures Available, Msg 04049212eight Seven or PM
R34 Stuff
R34 standard filter box bottom half only $10
R34 Standard Arms $Free
R34 GTT stockies $150
R34 Dash $50
R34 GTT Spoiler $80
R34 Coupe doors $50 each
R34 interior trim pieces $20 each
R34 Viscous Diff Centre $50
R34 Standard Gauges $60
R34 Rear Hicas Module $40
180sx Stuff
Sr/Ca gear stick/knob/plate $10
CA Manifold $10
180sx Black tail lights $100
180sx headlights $50
180sx pig nose front bumper $150
180sx rear bumper $50
Ca/Sr non abs tailshaft $50
Sr 20 carbon pod filter Cover $20
Ca18 a/c compressor $20
5 Bolt Dump pipe into 3 bolt $40
S14 Standard Fuel Pump Assembly $5
Rb20 engine complete in bits all parts available $125 for the lot
V35 Stuff
V35 Front Bar $250
V35 Rear Bar $250
Universal Parts
1x 18x8 +42 and 1x 18x9 +33 PDW Replay no tyres $20 each
New Nos Pod filter $5
Malpassi FPR $20
Intercooler 600x300x76 3” in/out $100
Hi there,
I'm after the following if you have any?
- GTR front lip
- GTR wing (must be genuine, 3pc wing. not fibreglass shit, got one alrdy!)
- RB20 coilpack cover. Prefer factory ones but will consider tidy aftermarket ones that cops will take nicely to!
Located south east Victoria, so will require shipping.
Sorry only have 5 RB20 coilpacks as I dropped one and the plug part broke so I just put it in my bin. coilpacks work just fine but I've upgraded to splitfires.
5 Coilpacks $30
  • 9 months later...
  • 3 weeks later...
My Box of Things Sale, R34, 180sx, RB20, RB25, S15, R32, SR, CA. Located in Tascott NSW 2250
R34 Stuff
R34 Dash $50
R34 GTT Spoiler $80
R34 Stock Turbo Manifold $30
R34 5 Bolt Drive Shafts $100
R34 5 Bolt Diff Half Shafts $50
180sx Stuff
CA Manifold $10
5 Bolt Stainless Dump pipe into 3 bolt $40
S15 Front Brake Rotors Machined and Sealed $50
R32 AWD RB20DET ECU $50
Updated 28/03/2016
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
