Regarding the pen marking on the back, this is actually from the factory! I have an R34 turbo with a similar code written on it, with the same pen. Looks like the same handwriting too :) I have found a few parts on the car with similar handwritten codes, including the gearbox.
Trying to work out if this is a nylon compressor r34 op6 or if it's been replaced at some point
Given the pen marking on the back I think this has been put on to replace the stock turbo
attachicon.gifImageUploadedBySAU Community1431140765.550349.jpgattachicon.gifImageUploadedBySAU Community1431140774.737286.jpgattachicon.gifImageUploadedBySAU Community1431140788.060474.jpgattachicon.gifImageUploadedBySAU Community1431140801.517041.jpg
https://www.sau.com.au/forums/topic/456471-op6-turbo-id/#findComment-7531284
Interesting! Having known the previous owner and it never being replaced I assumed it was done before he owned it
https://www.sau.com.au/forums/topic/456471-op6-turbo-id/#findComment-7531531
Some have had Garrett compressor housings , usually the give away in any RB25 OE comp housing is the anti reversion groove machined into the inlet snout that generally lines up with the tips of the inducer or inlet comp wheel blades .
A .
PS the VG30 single ceramic BB turbos don't have this groove and the comp wheel was slightly smaller . Plus the actuator and its mounting bracket is different to any RB based OE turbo .
https://www.sau.com.au/forums/topic/456471-op6-turbo-id/#findComment-7532748
A .
What turbo do you think I pulled off my car Anthony?
https://www.sau.com.au/forums/topic/456471-op6-turbo-id/#findComment-7532888
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
