2015 Sau Qld Annual Charity Cruise - 19/07/2015
Hey, I'm coming to the meeting point at Nerang station, but due to family committments I won't be making the drive out to Darlington Park.
And will I be able to get my membership pack Sunday? I haven't received it yet.
I would just like to thank everyone who came out the the charity cruise today. We raised a total of $1301 for beyondblue. I would like to give a special thanks to Stephen from Exclusive Wraps for once again providing us with stickers, Jims Car Cleaning Aspley for their donation to the raffle and Anna for her generous donation of $300.
Also a special mention to Martin for letting us use his Navlux for BBQ transportation.
  • Like 1
Omg,cruise was awesome food fantastic and company first class.Was told by some one behind me that I shot a flame out the zorst,first one in 13 years .Looking forward to cruising with you all again,I had a blast and thank you all for making this lil ol granny feel welcome. :-) :-) :-) :-)
  • Like 2
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
