Once built will be track days, time attack style events, and street. What other upgrades are there for under $2500. From what I've read there isn't much point in upgrading rears?
Thought if I went the 33 brake route I would obviously add I believe the disc are thicker also?
Wrong about the thickness. Normal 32GTR rotors are 296x32mm. The bigger V-spec and 33GTR rotors are only 30mm thick. Not that it matter at that point because they're going on for 30mm bigger diameter, so they weight more so they soak up more heat anyway.
If you can get them cheap, throw them on. They are an easy upgrade. But with a budget of <$2.5k, there's aftermarket options that are bigger and more worthwhile.
Alpha omega does a evo 9/10 conversion kit for r32s, he supplies the whole kit including brake lines
I have a set and It's an excellent upgrade and is within your budget
http://alphaomegaracing.com/p/50/c/73/Z33/ALPHA-OMEGA/Evo-350mm-Brembo-Brakes-Adapter-Kit-Version-2.html
Looks good, I notice they only do the fronts.
Is that because as per my last post alot of people dont upgrade the rears due to it being seen as something thats not needed?
Would it be a good setup to have:
Evo IX front calipers
DBA T3 4000 Series Evo X rotors (350x32mm)
QFM A1RM pads
Rear:
DBA T3 4000 Series Disc
QFm A1RM pads
Braided lines and good DOT fluid
Would an upgraded mastercylinder do anything significant? and if so what one would be good?
There's not really a need to upgrade the rears until you have really quite large fronts. At 350mm fronts you're starting to get to the point where the original rears are verging on too small, but I would certainly try it before considering a rear upgrade.
It is also possible to play bias games by selecting different brake pad compounds front to rear. Although it is certainly easier to take bias out of the back by putting less bitey pads on the rear than it is to put more bias on the rear by putting more bitey pads on - seeing as most people want to max the biteyness at the front. Still an option though.
I was doing some research for the same purposes as you and found the Alcon kits were not much over the $2500 you have mentioned.
All depends on your wheel size, but Brakes Direct offered this:
• Front 6 piston monobloc Alcon kit with 365mm 2 piece rotors $2697.
They were happy to swap out pads and upgrade to PMU Club Racer pads for a little more.
Shipping is free Australia wide.
Might be worth looking at as another option.
QFM A1RM pads
Rear:
QFm A1RM pads
He's currently doing a brembo conversion for the rears now..
I'm running mx72 pads with standard rears. It's a touch too bias in the front but its still good
You will need big wheel clearance and an upgraded master for good pedal feel
is the 17/16' master cylinder from the v spec 2 big enough or not?
with the T3 disc it might be a nice setup then.
would 17's clear? I am speaking to a factory my fathers company uses about doing some billet R32 GTR wheels in 17x9.
Just looking into what needs to be done to be strong enough or potential problems.
Not to hijack the thread but I'm currently restoring some R33 v-spec brembos to install on my BNR32. I have the adapter plates and braided lines figured out but I'm trying to source the best roors to use with these. Can anyone give me a rotor size that will work best?
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
