  • 3 weeks later...
paddleshift holinger?
its about $24k for a brand spanker holinger
add on gear read out display and subframe closer to $30k
and i think the paddle shift option is an extra $5-6k
plus shipping and installation
got 2x 32 builds going. Shitter is LS powered for track work, cammed, new tr6060 box with upgraded synchros, nismo lsd, AGI cage and basic suspension goodies.
No 2 is my good one, 26/32, gt42, t400, gtr rear etc etc, 7yr build so far
  • Like 1
Nice builds Corey! Got any pics to share?
Mine is sitting on axle stands at the moment as I'm changing suspension setups. Might give it a respray later in the year and then think about swapping out the current turbo setup for a precision turbo of some sort....6262, 6266 or even 6466 .... dunno yet, need to do more research! :D
2.6 or? i think simon has shown the sweet spot for a 2.6 is the 6262
No pics at the moment both shells are bare getting ready for paint. Both been on the back burner for the last 6 months due to being busy at work. Will get some up when I start tinkering again.
Damo, go the RPF01's they are nice. Why the hate for the XT7's?
I think they look good on other cars like a 4 door 34, I think they have just been on the car 2 years and i am after a change although car has only been running ~ 6 months of that hahaha
on that just purchased a set of RPF01s in black should arrive in the next week or so
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
