Aw man, That sticker looks clean. Can't wait to get my car on the road. Currently making a list of every thing I think may need work to get it over the pits... but hey, i'm no expert.
I've got some spare stickies if you want :) [emoji4]
  • Like 1
Hey, you still need to come round and share your thoughts with me. (peer pressure). Also, quick question car peeps: My Fuel Gage doesn't work, and my Rev meter goes spastic for 10 minutes and then decides to work.
Any ideas?
Could just be a faulty. Im no expert but could be as simple as replace gauge to sensors. Will look around and c if i can find any info.
Speaking of, has any one had any experience with getting a car registered? theres quite a few places that do it, was wondering if there are any that are preferred? I found an old thread from 2010 and it looked like back then, there was some independent places that were a bit more relaxed.
