Oh, I'm not actually getting much. The engine is perfectly fine and doesn't need any work at the moment. I'm getting some more cleaning stuff (running low on some things), a Headlight restoration kit, Microfibre towels!, some Mesh for the front skirt (I've been told it wont pass pits without it?), some valve caps for my tires (its missing them) and a lug nut...because im missing one and it annoys me. The plan tomorrow is to shell the interior (as best as I can) and clean it out.
The car has been sitting in a commercial garage in welshpool for 6 months collecting dust both inside and out, so before I can do any real work ,I need to clean it.
  • Like 1
I haven't got a time frame in mind. I'm in no rush because I have a daily (2014 Lancer ES) and my Motorbike ( <3 ) so the skyline is purely a hobby... but, the sooner the better, I guess. I don't think it'll take too much, but it's a first for me. I have a friend coming around possibly on thursday arvo to take a look at my cluster, because my Tachometer, fuel gage and boost gage don't work. So, if every thing goes smoothly it should be ready for the pits next week, maybe.
Thinking about making a thread to document the work.
Selling for a 2 door? ;)
SNAP!.
4 doors are where it's at man ;)
I know I need to take it over the pits, but there are obvious things that *need* to be done first. Once the obvious things are fixed, i'll take it over the pits and see what surprises me.
While you're on Z00key, Wanna tag along in the morning? (I'm leaving early, around 9ish)
    • A 1.5 way is a 2 way. It is just a 2 way with a less aggressive ramp on overrun.
    • The ABS and/or TCS being missing/broken will not cause the engine to misbehave. It just casues CEL to come on and annoy you. The CEL is useless if it is always on, so you have to do the things you have to do to get rid of it, so it can be useful. Being a Stag ECU, then yes, it will not expect TCS to be present. But it will expect ABS to be present and working. You will need to either make the ABS CU talk to the ECU (don't ask me what that will take on an NA R34), and make sure the hardware is working....or, you just need to blank it out in Nistune. Do not persist with the stock ECU. You will just have problems. Gte it Nistuned. Start from there. DO YOU HAVE A BOOST SENSOR? The ECU's boost sensor that it. It is connected to the loom at the rear of the coil cover. Usually rides on the firewall on an R34, but is usually bolted down to a bracket along with all the other crap at the back of the coil cover when a Neo is dropped into another car. If you do not have it, the ECU will shit the bed. So, do you have one?
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
