Oh, I'm not actually getting much. The engine is perfectly fine and doesn't need any work at the moment. I'm getting some more cleaning stuff (running low on some things), a Headlight restoration kit, Microfibre towels!, some Mesh for the front skirt (I've been told it wont pass pits without it?), some valve caps for my tires (its missing them) and a lug nut...because im missing one and it annoys me. The plan tomorrow is to shell the interior (as best as I can) and clean it out.
The car has been sitting in a commercial garage in welshpool for 6 months collecting dust both inside and out, so before I can do any real work ,I need to clean it.
  • Like 1
I haven't got a time frame in mind. I'm in no rush because I have a daily (2014 Lancer ES) and my Motorbike ( <3 ) so the skyline is purely a hobby... but, the sooner the better, I guess. I don't think it'll take too much, but it's a first for me. I have a friend coming around possibly on thursday arvo to take a look at my cluster, because my Tachometer, fuel gage and boost gage don't work. So, if every thing goes smoothly it should be ready for the pits next week, maybe.
Thinking about making a thread to document the work.
Selling for a 2 door? ;)
SNAP!.
4 doors are where it's at man ;)
I know I need to take it over the pits, but there are obvious things that *need* to be done first. Once the obvious things are fixed, i'll take it over the pits and see what surprises me.
While you're on Z00key, Wanna tag along in the morning? (I'm leaving early, around 9ish)
