Na after i got rear ended (car not me trev) and i dropped off car to be repaired im still in dispute with my insurance about quality of wk done but thats another story, but with the guys who did the work badly i pretty sure they took my car out for a thrash, so 1 of the reasons wanted it was limp mode (again trev car not me) but yeah if anyone wants to know where not to take a care for panel repairs i can let u know. I really wanted to name and shame them.
  • Like 1
Morning all!.
Up bright and early planning out todays work which if the weather lets up will involve removing rear tint, cleaning rear seats and carpets in car (any tips on getting sand out of this stuff?) and if time permits, washing the exterior.
A friend of mine told me he'd be coming around this arvo to look at the tachometer but that's a 50/50 at best. I have access to the rest of my tools, which means I can finally Jack up the car!!!. I'm mentally preparing myself for that, as i've been told the RB25's are real tight at the back (Just like z00key).
Also, yeah, the quality of work done on z00key's car was just heartbreaking to see, could have done a better job with cable ties.
Ok, so after successfully removing the interior from the car, and cleaning it all, I also did a quick plastic restoration on some of the older bits, that had lost their colour and changed to a chalky white. Here's a quick little before and semi-after.
http://imgur.com/a/jYMkw
All that is left to do now is remove the rear tint (bubbly and gross), Fix the Coolant leak, Mesh the front grill , fix my tachometer and brace my Pod Filter down. Once that's done, I'll take it over the pits and see what they find/complain about.
  • Like 1
Damn it, Just about to Jack up the Car and the rain comes back :( ... Go Away Rain, I'm pretending to know what i'm doing and you're not helping.
Actually, Hank, you do suspension work right? If you're ever in the Forrestfield/Wattle Grove area, the previous owner apparently had the suspension on the car "raised" to get it to pass the pits, but it's higher at the back, lower at the front. He had all the work done by pedders, I'd love to get your thoughts on what they've done.
Also, I want coil overs. Will wash cars for coil overs ;)
Edited by Manne
It's a split hose!!! I found the leak. The question is, how do I change this hose? I'll put some photos here.
It's a very small, short hose at the rear center of the engine.
Any one know which hose this is and the best way of tackling it? (from underneath or above?, tips?)
http://imgur.com/a/OkvpU imgur flipped the photo, no idea why.
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
