they said they're going to need another day with the car, I asked then if they could give me a progress report on the car, and they told me They've Replaced the Tint on the Rear window, and replace the springs in the front (it was too low at the front). I'm not an expert and I have no idea how busy these guys are, but they've had the car since Midday Tuesday and all they've done is put a layer of tint on the rear window and swap the springs. They told me they are currently working on the tachometer now, but the car won't be ready until end of day tomorrow.
Doesn't look like I'm bringing it to the cruise.
Hi do you guys know what process is to register a interstate vehicle in WA, have any of you done it ? Is it hard ?
I did search registering interstate but only found eastern state stuff.
Think you need to go pits , and get a road worthy Certificate , haven't done it my self tho [emoji28]
  • Like 1
Sad. They get pretty busy most days with engine rebuilds, mods and usual services. But pretty annoying they promised two days but took longer.
Being in similar environment, everyone wants to know when it will be ready
Go short and your a flaming mongrel if it blows out.
Go long and you miss out
Best guess is still only a guess
Right, Under promise, Over Deliver, retail 101.
I'm not upset that it's taking a bit longer, I'm disappointed because we discussed a time-frame, and they couldn't keep it, and they didn't ring me to tell me it was going to take longer.
Also, it took more than 24hours, just to apply tint to 1 window, I know they out-source the tint... but it doesn't take 24 hours to tint 1 window.
also, they charge by the hour, so the longer they take, the more I pay.
Ring around on places that tint c what the going rate is this way you know you wont be over charged, also you are paying for something to be done/service if you dont get said service then negotiate
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
