:D was good!
Hows your day been?
Had a mate I never see drop his car off for a service and hang out with me for the day.
Counter meal and few beers. Then beer at my place.
About to go out for dinner for my dad's birthday :)
No call from c-red so no info yet. Asked if i coyld be there for the dyno run but the guys said sorry :(. Mate of mine said usually reason they dont like people there watching as usually have issues or probs and they just wana get the job done, which is understandable
I actually popped in to see if you were at C-red today around 3pm, wanted to snoop. Your car wasn't in the car park, thought you had left. At least you know it was inside so they were probably working on it. Nice silver R33 outside though.
I've been in the dyno room both times at Allstar. He didn't seem to mind at all. Actually called me in the second time
I had the same at Allstar, happy for me to watch. I wasn't there when they did the Cossie at Rotos though.
Morning all!, Tomorrow is the big day.
Any advice you could give me for the inspection?, KYP told me I should quickly spray down my engine bay (its fairly clean), just to make the mechanic happy.
Not much, just be polite with them even if they are dicks. And if the car is clean they will less likely look around for leaks etc. Just take a deep breathe when they take it for a drive. The asshole that did my inspection gave it the boot. Was pretty annoyed at him.
  • Like 1
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
    • I'm a fan of the JZX110, and the Aristo. Big cruiser cars, and with the factory cars, super comfortable and feel like you're driving an armchair! And the JZ motors are a pretty nice engine too, especially with some basic mods.   The import process, and the need to be able to trust people, and the fact there's so many scammers around is what ever puts me off wanting to go through that ordeal!
    • I don't care for these at all, but at least the underside looks straight and not rusty. A good basis for a long life. Many cars from Japan have been lifted with forklifts and f**ked almost irrepairably.
    • Yes, but it's not dumb or dodgy. You can build a perfectly good boost controller from a pressure reg, a relief valve (looks same same as a reg if all from Norgren or SMC, for example) and a check valve. I ran one for years. Only superceded with  EBC because I could get one for cheaps and wanted finer control.   THis mod is certainly not a sketchy boost mod, provided the boost is kept below the "spin to death" threshold of the turbos.
