What ???? Homemade Ice cream ? Like for real ? Wow ! [emoji119][emoji119][emoji119][emoji122]
Longish hair with facial is very very sexy Collin ! attachicon.gifImageUploadedBySAU Community1464583280.918033.jpg
I'm a small asian guy....lol
My weekend begins today. Going to seal the taillights so water doesn't leak into the boot anymore and also start removing the rust from the boot. As always will post before and afters But that's the plan for this week.
Good Luck Manne [emoji123] hope you sorted it out
What's the plan today Elle?
At the gym now Trev, burning some fats [emoji22] and hopefully I can shake this yucky felling off
Are you at work ? What's your plan for today ? Lawn mowing ? Fishing ?
Edited by ElleAli76
Bonfire ! Marshmallow [emoji13] hahahahaha nah! Sounds like a hard work ! How's your family doing ? When are you guys visiting Kong again [emoji28] come and say hello I'll get Dave to fire up the Barbie
