Wow that really bad recording like if he was really scared that someone will tell him off any minute.
My give on this if you go to meet expected people to take pictures n video if you don't like it hide you car in a bubble at home.
Thats a nice number plate
  • Like 1
I play ps4, and retro too.
This idiot left his lights on.
Wana do game swap like boomerang style.
i have ps4 n 3 and sega mega drive 16 bit working .
Dont have many games but.........[emoji17]
Dont you look back at your sexy car...? You would of realized they on [emoji12]
PC. Never got the hang of using a controller. Keyboard and mouse still feels better for me.
Battlefield 2 on PC was the ultimate for me. I lived above a computer business in QLD and had massive LAN games of this.
I now have xbox but play only 2-3 hours a year. Mostly played first person shooters, shift2 and guitar hero
  • Like 3
Clearly you didn't take a good look at my car ;)
Also, don't take this the wrong way but I don't trade games, maybe ask Z00key about that ;) his collection is bigger than mine.
  • Like 1
Everytime we are in the car regardless of conversation etc I yell "skyline" when I spot one.
"Do you wanna go shopping at SKYLINE coles or woollies" etc
Half scares her, half just irritates her :)
  • Like 1
So just got home from mates place what we managed to do was front reverse camera (as my car is quite low can now see how far i am from taping anything in front) crash cam with both front and rear cams (wired in a 2nd cig lighter behind dash so cables are nice and neat behind dash and in roof) installed new top center dash piece (URAS center cluster same brand as my body kit) and new guages to fit in them but atm only cheapies and am not thinking very accurate. But a very productive day.
    • Guys since i bought r33 gts25t coupe 1994 automatic a/t(manual swap 350z gearbox)  all i got is problems, always problems. Lets start with that when i turn key into ignition(ON) fuel pump doesnt always works. Sometimes i have to turn key twice Off/on/off/on until it primes. Its new, dw300 - 340lph. My gearbox broke so i did gearbox swap, install different intake manifold, injectors and i take pipes. Car was sitting in garage for more than half a year. I did assembly all not that long ago and when i turn ignition cant hear prime. All of sudden it stopped working. Theres many videos on YouTube how to make relay mod on r33 straight from battery so i did and it doesnt work! 😰 30 - battery positive  87 - positive from fuel pump to relay 85, 86 - one of two wires from original fuel pump wires(light blue, grey) and it didn’t work. so I check on ignition and took original BLUE relays wires from trunk, next to fuses. (I believe it’s IGN+ and ECU pin 18. it didn’t work…  tried connecting (IGN+ from og relay) and (ECU 104 from 1of4 FPCM wires) to my new relay 85/86 and it didn’t work.  I unplug FPCM. Didn’t work. im thinking what’s wrong   fuel pump is working, if I leave IGN+ on 85 and 86 straight to ground it works but it’s just nonstop. Since it getting constant 12v after key in ON. light blue wire gives me 6-8v.  so how this should be connected? What causing ECU not giving — on pin? Or I did sth wrong and that’s why it doesn’t work? I need negative signal on ECU that control fuel pump. What this should be?
    • You can use your VIN to look up the factory part number somewhere like amayama, and then look to order new if necessary. https://www.amayama.com/en/genuine-catalogs/nissan Depending on price you might want to rebuild instead. @GTSBoy I had an interesting insight into US market parts when the Titan rear calipers were sticking. New calipers were dirt cheap, about 20% more than a rebuild kit....they are just considered throw away maintenance items
    • Funny, but really not funny. Thank god (most) f the world has moved on since then
    • Lots of votes for driving onto a plank first; that is the quickest way I've found, 25mm is enough for my case but that will vary by car It also depends where you are going for. On the 32 I can get to the rear diff with my floor jack if I do that end first, and get it up on stands. Then I lift the front from either front tow hook as high as needed, also onto stands. Sometimes I need a small lift on the other tow hook to get it level enough If I do the front first I can't get to the rear diff because of the angle of the car Other options are getting to the front mount of the rear subframe from in front of the wheel (if only lifting one side, or just do both which is a bit of a pain compared to one lift from the diff), or also the gearbox cross member mount on the driver's side if you are  just trying to lift the driver's side. I This is the jack I use; it says 75mm clearance but of course that is only on the lower section so if you have to reach too far in like the diff you still get stuck. https://www.snapon-bluepoint.com.sg/category/Floor-Jacks/product/Floor-Jack,-2-Ton-Low-Profile
    • On the bright side, the weather will turn much nicer for working outside shortly....sounds like you might need to start on a neighbour's garden next
