If every thing goes to plan I'll be giving the car a full service this Tuesday.
Don't waste monies on expensive spark plugs if your doing them
Bcpr6es for $5 each. If they only have the bcpr6es-11's then gap them to 0.8mm yourself.
$100+ cheaper than iridiums which aren't needed
  • Like 2
Interesting. Why do you say iridiums aren't needed?
Did Poologger do that? If so i'm kinda pissed be didn't want to work on my car looks mint! can't wait to see it in person.
Na it wasnt him, not actually seen him in a while. Was old mate from wk cost me a onkyo amp and a pack of cigs plus I gave him a 5k sale ;)
Im gonna be a pain and ask "why is that?"
Copper is best conductor, almost as good as gold,and less likely to overheat
Platinum and iridium don't conduct as well and can overheat. They may last twice the distance if not overheated but cost 6 times more
Copper- best performance. Shortest life $5
Platinum- ok performance. Ok life $25
Iridium- ok performance. Better life $30
There isn't that much in it really performance wise but big diff in price.
  • Like 1
So considering I don't drive much at all (probably 10,000kms per year) I should just get platinum/copper?
Also, morning all, nice, cold and wet this morning!
Edited by colin.ssc
  • Like 1
Ok so my oil filter was stuck on all of my tools couldn't get it off. They were just denting it pretty bad. Desperate to beat the rain I rung C-Red as I was just around the corner from them and Mark let us borrow a tool he has to loosen it. What a top bloke, saved the day. New filter is in and the oil has been changed. Can't recommend these guys enough!
  • Like 2
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
