Ellie, out of curiosity, what does Nissan charge for an oil change on a gtr?
Thru Nissan's from my first experience $4250 and above depend on how many K's but thru Galvsport in ozzy park $350-$400 ! Bargain ! And mind you they are very very good , using only genuine stuff and seen many nissan's owner ( brand new R35) servicing with em
$4250
What did they rebuild engine at service?
Ripped off :( apparently they ordered all spare parts from Japan and took time bla bla bla but yea I did fall
For it for the first time until I met Galvsport
That's amazing. I'm a diy kinda guy, it only costs me about $50 in parts to service my vehicles.
Dealerships never cease to amaze me.
I diy for my work / daily car but won't take risk for my 35 [emoji22] too complicated ! How did you go with fixing your door? Should we organise some fund raising car wash towards your door ?
    • Hell, I'm sufficiently wary of the ZSS suspension arms, let alone something like a hub.
    • Got it back home and got started pulling the hub off and diagnose the issue. Axle was stuck after removing the 36mm nut so i used a 3 jaw puller to try and push it out and... eH5FXvJ8.mp4   spend the next few hours trying to remove the axle from the remaining hub as it was very much jammed in there when the spindle sheared off. resulting damage as below R53AIy6 - Imgur.mp4   Looks like the was already a stress fracturing in the spindle as can be seen with the darker cracked section My working theory is maybe when the pinion gear exploded last year the shock put through the hub was the initial crack. Then a few events later it finally let go. Just lucky it happened where it did and not 190km/h on the next sweeper or into the hairpin The bearing/hub assembly went in in 2019 and were non-genuine "ZSS" assemblies and no nails were harmed in the process. #BreakHubsNotNails
    • Thanks mate, couldn't find in VIC, ended up ordering one from NSW, getting rwc to get new plates and registration done.
    • Before all the EFR fan boys come in, have a look at: https://www.garrettmotion.com/racing-and-performance/performance-catalog/turbo/g-series-ii-g30-825-58mm/ It also comes in a T4 1.06 divided housing. I would dare say if you want response & also decent power, this thing would chop.   AND apologies, just re-read your post, you've already bought the turbo... whatever you do, make sure you stick with divided housing and proper twin scroll manifold.
    • People have got to stop doing that. ShatGPT is not a search engine. It is a hallucination factory.   I also would recommend the 1.05. The .83 will "work" for you , in that it will be more responsive, but I think you'll find that it won't be anywhere near as good running it out to 8000rpm as the big housing will be.
