2 minutes ago, pol1on1 said:
Yeah nah i think im having more then general issues.
Eg.. my http link did not post ive had no participate activities in the lasth months or so and that what i use to use and now just finding this thread was a challenge but i re subscribe to it.
Time will tell until the next update.
works well for me
Found a good article about how to "tune" my boost controller rather than just set.
Checked mine and the gain rate was set at only 7% and limiter not setup.
Preliminary test appeared to gain response from 1bar @3400 down to 1bar@3250 at 70% gain and not spiking.
Fuel light was on so will further adjust and set limiter later
  • Like 3
My mate has nearly finished his rx7 (series 3) build, yesterday sent it off for a tune and told them to do a conservitive tune it came back at just over 415 i think, i told him im not going in it with him driving. Anyway last night he took it for a spin and he sent me a pic will post it up in my next post
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
