2 minutes ago, R DIRTY 3 said:
hey man. Yeah im still alive. Hows things there? ?
It's going alright, up and down, some days busier than others.
Jarrad has an office job now which is pretty funny.
  • Like 1
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
