Issue I had with adoption agencies is that I never had a pet before and so they weren't too keen on giving me one.
HRWA are not like that, they just want to ensure you know what you are getting into, Huskys are a unique breed and are extremely active
Malamutes are just huskies on steroids.  all my animals are sleeping because they live happy relaxing lifestyles. my dog gets two 8km walks a day.
Oh, and yeah, adopt one. there's so many out there.
Edited by Manne
  • Like 1
Yea ok I'll have a look. House doesn't have an alfresco area. Ideally I'm hoping to get that up at least for work out door shade area for the dog.
Have a chat with Anne, as long as you know what your getting into you will be fine, they charge $400 for costs of desexing, microchips and worming etc
http://www.huskyrescue.com.au
Tell her I sent you 0413 770 092
  • Like 1
I don't have a very large house, in fact it is quite small. To make up for this, I take my dog for long walks and play with him at the park, which is perfectly fine. We'll play tug of war in the yard and sometimes we wrestle, he's 55kg...decent opponent.
  • Like 1
No wonder your knees are shot 16km per day plus walking around at work [emoji15][emoji15]
  • Like 1
35 minutes ago, shoey85 said:
No wonder your knees are shot 16km per day plus walking around at work emoji15.pngemoji15.png
So about that, I have some sort of Chondral Fissuring of both knees. Essentially, the Cartilage for both knees has deep cracks and fissures through it, some of it has also started peeling off of the bone, and there a small, loose bits of cartilage floating around the knee too.
Theres no surgical options, supposedly (Rheumatologist tells me that, so does my GP and Physio), so the best Cure is to Grind back the Cartilage with low-impact leg exercises.
I had to buy a particular Exercise bike, that has a heavy flywheel (7kg), set the resistance up, so it's like pushing a weight, a slowly do that for 30 minutes a day. This not only builds muscle, but grinds back all my broken cartilage, and hopefully creates a new groove for my knee caps to sit in. Unfortunately it's a long, slow, painful process, slowly improving every week.
Option B is to take Anti inflammatory pills for the rest of my life, with monthly (expensive) Steroid Injections and fillers (with the risk of infection from each one).
Fux man that's really not good, hope
You do get better sooner rather than later!
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
