When r u doing the car parts shopping? [emoji6]
Morning boys :) car parts tomorrow ,
We have to make a phone call to let them know we're coming , thinks it's like Nismo garage / workshop where you can tune your car
And shops[emoji28]
  • Like 3
Its very nice i wish i could buy it.
For what he has done to it its good value compared to east.
Went up on Facebook 4 weeks ago and viewing starts on 16th of January from memory.
Cheers anyway.
Ill try hunt for a nice r32 .
  • Like 2
Morning boys [emoji4] car parts tomorrow ,
And shops[emoji28]
Wouldn't mind a new exhaust [emoji28]
  • Like 2
