Its just not the same. And that cat back pack is cool
I know [emoji24][emoji24][emoji24] I've tried tho and the website says it open [emoji35]
Oh yea the back pack is good , I need a stroller tho , as I have 3 babies xx
  • Like 1
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
