Specs:
Mobo - Asus ROG Rampage IV Black
CPU - 2011 i7 4930 - @ 4.6
GPU's - 2 x GTX 1080 Hydro Copper
Ram - G.Skill Ripjaw 16gb (4x4) @ 2400
Case: Phanteks Enthoo Primo
Water Cooling :
EK Supremacy Gold CPU Water Block, GPU's stock WB's - Classy HC's
Rads:
1 x EK 480 x 60mm Rad for GPU's - 8 120mm fans Push Pull
1 x EK 240 x 60mm Rad - CPU - 4 120mm Push Pull
2 x D5 Vario Pumps with EK X-Top pump tops
NZXT External touch screen Fan Controller
Hard Drives:
2 x 1TB Samsung Evo840 SSD in raid 0 for OS and games
256GB SSD for Downloads
600gb Velociraptor for general data
PSU - Corsair AX1200i
OS: Windows 10 64 bit
BitFenix Alchemy blue LED lighting 600mm x 3 and 1 white 600mm
Monitor - Asus ROG Swift PG348Q
ASTRO A40 Headset
Logitech G700s Mouse
Logitech G19s
Old pic from when I first built it update pic next week [emoji12]
KeyboardIMG_1483585283.790842.thumb.jpg.c2bcb97b
  • Like 1
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
