Specs:
Mobo - Asus ROG Rampage IV Black
CPU - 2011 i7 4930 - @ 4.6
GPU's - 2 x GTX 1080 Hydro Copper
Ram - G.Skill Ripjaw 16gb (4x4) @ 2400
Case: Phanteks Enthoo Primo
Water Cooling :
EK Supremacy Gold CPU Water Block, GPU's stock WB's - Classy HC's
Rads:
1 x EK 480 x 60mm Rad for GPU's - 8 120mm fans Push Pull
1 x EK 240 x 60mm Rad - CPU - 4 120mm Push Pull
2 x D5 Vario Pumps with EK X-Top pump tops
NZXT External touch screen Fan Controller
Hard Drives:
2 x 1TB Samsung Evo840 SSD in raid 0 for OS and games
256GB SSD for Downloads
600gb Velociraptor for general data
PSU - Corsair AX1200i
OS: Windows 10 64 bit
BitFenix Alchemy blue LED lighting 600mm x 3 and 1 white 600mm
Monitor - Asus ROG Swift PG348Q
ASTRO A40 Headset
Logitech G700s Mouse
Logitech G19s
Old pic from when I first built it update pic next week [emoji12]
KeyboardIMG_1483585283.790842.thumb.jpg.c2bcb97b
  • Like 1
    • I thought it could be an issue because the standard plate was flexing when stressed. Maybe the original gear set will hold a bit better without flex? Last time on the dyno it made around 670nm at the hubs. Now it have bigger turbo and better intake but have not been on a dyno yet. The car is being used from family trips to drag race events. So the shifts can be a little violent. It is grinding if I shift to fast so was thinking I should overhaul it soon.
    • From the factory on RB26s there's a fitting on the intake manifold collector/"plenum" that provides pre-throttle boost signal. That's how they did it back in the day, I figure it's fine to replicate it.
    • I would be surprised if that wasn't the issue. It's probably telling you, that even if you remove the plastic liner, you may have some other clearance issues that may occur too in some scenarios. IE, tyre to guard. It looks like someone has already rolled the lip, but you may still have issues in the future IE, turning and hitting a bump etc. The fact it changes how bad it makes the noise when you are going backward vs forward is highly indicative that it's the tyre rubbing. They do make a terrible sound, even if you're only pushing a project car that has a liner hanging down on a tyre!   Has the car been lowered? If it has been, what is the measurement from the centre of the wheel hub to the lip of the guard straight up?
    • Summernats cruiser?
    • Mark's a bit smarter than people give him credit... He'd convince the person that is to become dead, to drive him to the forest first. That way his car has no evidence in it, and he's free to dispose of their vehicle permanently how he sees fit too...
