55 minutes ago, ElleAli76 said:
That's fine Justin :) If I can't wait then I'll
Just pop in to Apple Store , don't think
You guys do 512 gb apple
Laptop emoji335.png, saw the 256gb only I think
If it's not on our website probably not, but I won't know until im next at work.
  • Like 1
1 minute ago, colin.ssc said:
If you want, try Freeway Smash Repairs in Osborne Park. They do really good work. They fixed my car up v well, good paint job too..let me know and I'll let him know to expect you?
Not today, the air-con in my skyline doesn't work and I used 1/4 of a tank going to mandurah and back.
The guy told me i'd have to get a new front skirt (at my cost) and then $600 to paint and fit it, as he won't repair the existing.
Then he wanted $450 to pop the dent under my drivers side mirror, and another $600 to respray the door to match.
Then he wanted $1000 to remove the rear skirt, pop the dent, fiberglass the tear and then respray and fit, or $600 if I supplied him with a new rear bumper, and he would just paint and fit.
You can see the dent on the side in the photo attached, have no photos of the rear at the moment.
Yeah, after he went inside, I looked at my friend and said "You're kidding me right?" and he thought it was a good deal.
In other news, I've been quoted a maximum of $500 to fix my Air-Con, roughly $200 + whatever a fan for an R33 would cost (depending on the issue)
Edited by Manne
Ok, booked the Skyline, and my Lancer in for some Paintless Dent Removal, should be fun.
I spoke to three different places and decided to go with Dent Dismissal, as he seemed to be the most knowledgeable after a small discussion over the phone. There was a guy called The Dent Man, who was $50-$100 cheaper, but he basically just said "shouldn't be a problem, will come up good", where as Dent Dismissal gave me more information, "Based on the location, sharpness of the dent i'll have to do X and Y, could take a little longer depending on how it comes up, I've not worked on that car before so I don't know how long it'll take blah blah".
Will let you all know how it goes.
Edited by Manne
  • Like 2
Mother in laws passport should be ready any day. We spent the money we had put aside on the house. Getting a bit of overtime lately so it's still possible but my wife said on the weekend she would like to go for New Years instead so I'm not sure what will happen
  • Like 1
    • Apologies for the long post, but needed somewhere to lay out the entire timeline of events and actions taken:   I've got an 89 GTR with a R34 RB in it. It's been running great all year, driven probably 500KM in the last month. It's not my daily driver, just a weekend fun car.    Build info: R34 RB26 - HKS 2.7 stroker kit, HKS adjustable cam gears, HKS turbo upgrades, Trust intercooler, R34 factory DENSO 440cc injectors, JUN chipped/tuned R32 ECU. All of this work was performed in Japan back in 2019.    Thursday 10/2/25 - It's a nice day and decided I'll drive it to work, I start it up in the garage and I notice it took a few extra cranks and sounded a bit funny. I figure maybe it was just because it was a pretty chilly morning. I pull it out into the driveway to warm up a bit before leaving. As I leave the driveway, it feels very off and sounds like a misfire. I pull it back in the garage to deal with after work and take the daily to work. I was able to diagnose it as a cylinder 5 misfire with the old spark plug test (unplugging each plug until a sound change with the engine running). I take off the whole ignition system, ignitor, plugs, spark. *Important note, it is still on the R32 ignition system with the separate ignitor system. I test each system with a multi-meter and nothing presents as a smoking gun. I put it all back together and it starts up no issue. I go ahead and order the PRP R35 ignition conversion kit. It should arrive today (10/13/25)   Friday 10/3/25 - Another nice day, car starts up great and drives great all day. Very pleased that everything seems to be OK   Sunday 10/5/25 - Decided I'll take it to play some golf, load up and drive to the course about 25 minutes away. Drives wonderful the whole way there, I pull in the parking lot and the engine completely comes to a stop. I do not recall if it sputtered at all, but just remember all of the sudden the engine was off. I roll it into a parking spot, try to crank it back on and nothing.  It'll crank and crank and not even try to start. End up getting it towed back to my house and push it up into the garage.    Items I have checked: Fuel in the tank Fuel Pump relay Fuel pump fuse  Spark Plugs & gap Coil packs Ignitor    I know the cylinders are getting fuel as the plugs smell like fuel after a start attempt. I tried spraying starter fluid into the manifold and cranking and not even a sputter.    I decided to do the live CAS test (removing the the CAS, ignition on and spinning the CAS stalk to see if the injectors pulse and spark is active). All of the injectors were pulsing and I have spark at the plug. The half-moon end of the CAS did seem very loose, I'm not sure how much play is supposed to be there, but it was more than I expected. There was no in/out play of the shaft, just the tip end that is pinned on had quite a bit of play.    CAS Play video   When I put the CAS back in, I stupidly did not re-time the engine. I know I need to do that tonight, however, I do not think it will start given it seemingly was not the issue. My plan is to do the PRP R35 coil kit and retime the engine at the same time.    I plan on ordering the Haltech Nexus Plug-in ECU once they are available again, but ideally would like to get this sorted before firing the parts cannon at it and potentially adding more variables.    Anything glaring that I am missing here, I'm a bit at a loss?
    • Get it on a dyno. Get something logging Consult. Run it up and find out what is causing it.
    • Looking for a plenum for rb25 de+t neo  Not looking to push much power maybe 300kw at the wheels, is there much difference in flow for Freddy “Greddy style” compared to original Greddy or options like Proflow or Otaku garage?    I won’t be porting the de Neo head for now as I think it’ll be fine 280-300rwkw but appreciate the help and any experiences anyone has between them and any advice. Thanks  Looking at this plenum for now below
    • engine wise almost no mods: stock ecu Greddy front mount intercooler Greddy forward facing intake w R33 TB stock fuel system, stock injectors, rail etc. Kakimoto racing hyper 3 inch exhaust system Apexi intake filter New NGK –R BCPRES (.8 gap) plugs
    • Nice one @Pac - looks like a fair few 1600's there!
