18 hours ago, Hank Scorpio said:
Corey/Trev/Dale
Chucky is busting my chops do go down your way.
1st, 2nd or 3rd Saturday of February, what do you think?
Gona have to be the 3rd sat (18th) for me. Otherwise you might just have to take 1 on the chin for the team :19_kissing:
Yeah, nah :P
3rd sounds good.
TREV! Make your bitch ass available.
  • Like 1
16 minutes ago, shoey85 said:
Any one going to race wars this year?
My mate might be moving down to Albany, if he's there I'll go. Not entered though.
  • Like 2
