Soz Trev. Just saw your msg. The gf wants to go out for dinner [emoji37]
The woodfire pizza at the Tavern is super and my wife probably will have chilli muscle.
Oh btw the tavern is run by wogs so tell her ull take her to an Italian restaurant. [emoji6]
  • Like 1
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
