Liquid limestone. Just finished prepping 2nd area. Quick bite to eat and I'll fire the mixer up default_wink.png
I have 3 kids and didn't get sleep in at all [emoji23]
12 hours ago, t_revz said:
What's the difference between x and black? Car price? How many levels are there?
There's UberX (normal), Uber-maxi whatever for large group and UberBlack which is swanky af.
Everytime you go up a level you pay more.
From what i know uberx is $1 per km while black (top class) is $2per km now there is one more in between its people carriers.
Also i did get charged a uberblack flagfall of $2 and 18min in car was $5.60.
  • Like 1
How much should I charge if I use my GTR [emoji38]
Went to work straight into nightshift did not sleep at home or plane was up for 22hrs. Went to sleep i can't sleep now after i woke up from 3.5hrs of sleep [emoji27] [emoji22]
Huh ? Too much sleeps ?
Im using my PC, don't notice a new layout.
Did some things to my car today, found out some new troubles with my car today as well.
Got some Quotes.
Back to saving $$$$.
Time to move it on b4 you overcapitalise
  • Like 1
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
