24 minutes ago, pol1on1 said:
Ok no problem
Is your car the one from down rockingham way? There was a guy selling both his gtrs, one was silver and striped out with a cage, the other was silvwr with a 400r bodykit and -5s under the hood
  • Like 1
Morning all!!
I may need help getting this red beast over the pits, my tyres are slightly too big as the guy that recommended them was unsure of the size I needed and I had no idea. So I may need to borrow someone's that are the right size [emoji7] (name your poison). Also I may need to source inner guard liners for the front as it was rubbing the shit out of them so they went in the bin [emoji24][emoji24]
Will know more after first inspection this week, wish me luck!!
  • Like 2
Morning all!!
You can borrow my rims if they suit, I'll be home Wednesday to discuss further.
  • Like 2
14 minutes ago, shoey85 said:
Morning all!!
I may need help getting this red beast over the pits, my tyres are slightly too big as the guy that recommended them was unsure of the size I needed and I had no idea. So I may need to borrow someone's that are the right size emoji7.png (name your poison). Also I may need to source inner guard liners for the front as it was rubbing the shit out of them so they went in the bin emoji24.pngemoji24.png
If you're willing to do the legwork of removing them and putting them back on you can borrow my rims and guardliners. (R33 and R34 are interchangeable, my front left is an R34). Not sure if rims will pass as the front left is bent (only noticeable at high speeds)
  • Like 2
Morning all!!
Just rock up with my car , I'm sure you will
Pass with flying color ? lol kidding !
Wait service at Honda..... Feel like I'm in Japan again [emoji7]
  • Like 1
2 hours ago, shoey85 said:
Morning all!!
borrow mine just put some new rubber on it for me :P
  • Like 1
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
