24 minutes ago, pol1on1 said:
Ok no problem
Is your car the one from down rockingham way? There was a guy selling both his gtrs, one was silver and striped out with a cage, the other was silvwr with a 400r bodykit and -5s under the hood
  • Like 1
Morning all!!
I may need help getting this red beast over the pits, my tyres are slightly too big as the guy that recommended them was unsure of the size I needed and I had no idea. So I may need to borrow someone's that are the right size [emoji7] (name your poison). Also I may need to source inner guard liners for the front as it was rubbing the shit out of them so they went in the bin [emoji24][emoji24]
Will know more after first inspection this week, wish me luck!!
  • Like 2
Morning all!!
You can borrow my rims if they suit, I'll be home Wednesday to discuss further.
  • Like 2
14 minutes ago, shoey85 said:
Morning all!!
I may need help getting this red beast over the pits, my tyres are slightly too big as the guy that recommended them was unsure of the size I needed and I had no idea. So I may need to borrow someone's that are the right size emoji7.png (name your poison). Also I may need to source inner guard liners for the front as it was rubbing the shit out of them so they went in the bin emoji24.pngemoji24.png
If you're willing to do the legwork of removing them and putting them back on you can borrow my rims and guardliners. (R33 and R34 are interchangeable, my front left is an R34). Not sure if rims will pass as the front left is bent (only noticeable at high speeds)
  • Like 2
Morning all!!
Just rock up with my car , I'm sure you will
Pass with flying color ? lol kidding !
Wait service at Honda..... Feel like I'm in Japan again [emoji7]
  • Like 1
2 hours ago, shoey85 said:
Morning all!!
borrow mine just put some new rubber on it for me :P
  • Like 1
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
