If you're actively working as one, I'd love a quote on my skyline.
Unfortunately not any more.
I left many years ago but have painted a few cars at home for family. Last one was shoey87 nissan pulsar sss with a sr20det conversion. One befor that was my dads triumph sprint 1977 full reso running a sr20det. Both where flow coated and came out like glass
  • Like 1
Fair enough :96_ok_hand:
Any pics of the triumph?
  • Like 1
On 3/27/2017 at 1:22 PM, pol1on1 said:
Garrett 2860-5 turbos
Trust hard intake pipe kit
HKS dump pipes
HKS front pipe
Hi –Flow cat (Venom)
Tomei Ti Extreme – 3.5” titanium cat back 110mm intercooler.
Very flowing now got to save up and do my head port polish n 1mm oversize that would be my dream and cams n lots of stuff thats out of reach haha emoji12.png
1mm oversize i doubt would be required unless aiming north of 800hp. bigger ports n valves means more flow but the airspeed slows down and sometimes wont mix as well. bigger isnt always better. i would definetely research more before going down that path.
HeadTorque in Ossie park did port n polish and modified the chambers on mine. they were great to deal with
  • Like 1
On 3/27/2017 at 7:22 PM, pol1on1 said:
I got 19psi on stock internals 412hp just slaps some sticky slicks on and say bye bye to the lumpy v8 that thinks his cool!
Haha
you must have a heap left in it. -5's are good for around 400KW at the wheels IIRC
  • Like 1
so i setup the Water/Meth on my Rodeo before going away Monday,
holy fark it makes some powah now!!! as soon as the pump kicks it, boost jumps up about 4psi and it pulls like a train. Id say it makes 30-40% more powah now. i just hope it doesnt throw a leg outta bed :blink:
  • Like 1
30 will bust it [emoji4]
Pffft
I had more than 42psi and it didn't bust, it just threw raw unburned fuel out the exhaust as it was so rich and timing was so retarded.
It made more than 42 but I don't know how much as that's as far as the map sensor read. Still made 300kw at the wheels while doing it too.
Just now, TiTAN said:
Pffft
did you go full retard?
  • Like 2
naa, it fluctuates when i move the cable at the pyro. Id say cos the engine rocks lots at idle the cable may have failed. i just fitted a new one and it only lasted 2 days. ill email to see if there is warranty
    • I hope it's actually possible. This is a write off in insurance world.
    • Yup. 2-way with shallow ramp angles. Still works.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
