@turboedsloth Hey Corey, off the top of your head do you know the catch can capacity? i filled it in 400km. im going to fit/modify baffles in the rocker cover next week.
PS i need to take you for a drive and show you how much the methanol injection affects my ute :D
Go hard or go home!
U shouldnt need over sized valves, just a port clean, polish and port match.
Anyone on Instagram?
I made near 400kw with nothing but better valve Springs to hold more boost. No porting or cams or valve upgrades, not even port matching, Just extra boost.
394kw @ 26 psi on a 25/30. Gt35r (2007 spec) 6boob manifold, 3.5" exhaust with 2 massive mufflers so it was 90db @ 3500rpm, 4" intake, 3" intercooler piping, 4" Chinese ebay intercooler and a legit greddy intake manifold with q45 TB.
Everyone needs to stop being so girly with their boost levels, turn it up till it stops making power not some silly oh I can't have more than 20 attitude.
Learn to not fear the boost but instead embrace it and make bulk midrange power with all that extra air.
  • Like 2
I couldnt agree more, im the uk we turn it up and see what happens. If it holds 3 bar then it holds. If it blows ic pipes of u have the tools in the glove box to refit and if mr rod and piston make a sharp stage right exit u call a tow lol
Whats the point in paying all that money to go small? I can understand the risk factor, drop all that cash and watch it potentially disapear up in smoke but i guarantee ul have a big old smile on ya face ?
  • Like 1
Whats the point in paying all that money to go small? I can understand the risk factor, drop all that cash and watch it potentially disapear up in smoke but i guarantee ul have a big old smile on ya face [emoji16]
Im guessing no wife lol
  • Like 1
Married for 5 years and about to buy a house lol i just dont see the point in building a motor to hold say 600 hp and then only run it on 350 or 400, u mite aswell build it to that level and save urself the cash
  • Like 1
Reliability coz i want it on max psi setting always so every turn i do i give it to it.
Not a one off thing when i see a falcoon.
Standard gaskets n studs ?
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
