12 hours ago, ElleAli76 said:
Er actually I catch this thing that I don't know what's wrong with me from Dave lol emoji23.png
Slightly better but still no eating sign :( I tried some soup emoji501.png but yeah didn't feel good after I ate em
Awwww Daaaaaaave!
  • Like 1
The boys at C-Red got the car ready for the pits today, should be all good for next Friday, removed the highly illegal race parts lol
Mine is ready ! I need a quick wash , I've done the details [emoji28]
  • Like 1
Yer I wasn't worried about cost just wanted something to last and something with a nice note.
I bought a 100cell cat, a long magnaflow for the centre and a bigger one for the rear. From super cat converters in Wangara. It's 3" from the turbo. With the dump pipe running parallel plumbed into the first bend at the bottom so the exhaust draws it along. You can get the magnaflows at 3" I/d and put 4 slots in it and use accuseal clamps to seal it.
Anything would do the job on a budget, u can get a full system on ebay for 300 bucks
DSC_0219.jpegDSC_0144.jpegit really takes out all the high note and gives it a beautiful deep sound. It also runs pretty quiet when cruising considering 115 is 3000rpm.
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
    • Trailer got new mudguards to accommodate the new wheels Lightweight ally Painted, stickered and done ✅ 👌
