Hmmm nah not just yet just thinking what my problem is.....
I see a como on the up ramp givenn it some hurbs so i decided to downshift from 3rd to 2nd buttt.... then in 2nd i drop clutch revs shoot up to 6ish K then step on it and nothing......? .....? ....? So i take foot off revs drop down to 5k step again and she sings to me till 8k but by then im a fool and im scratching my head why did it do nothing revs hardly went up like if it had no air or fuel.
How long were you at WOT at 6k? Did you notice boost pressure while it was happening?
Did not look at boost but i would say 3sec then i stopped as i did not want to damage anything.
At the moment of intrest it felt like a wipper sniper running out of fuel with the finger on at WOT but maintaining the 6krpm. Ill maybe go of a spin again and set my video camera up on the gauges. All depends on how sleepy I am.
Wouldnt get this with 2 of the big ones [emoji23]
2x gt35
Go for an easy 1000hp, may not see boost till 6k though.
On second thoughts, replace the 26 with a cammed ls7. Have as much power as the -5 turbos and none of the lag or oil issues.
4 hours ago, TiTAN said:
2x gt35
This is true, but u cant beat the sound of a straight six on song ?
  • Like 1
1 hour ago, ElleAli76 said:
Kieran are you going to evo Vs wrx racing tonight ? It's in kwinana
Na, gotta pick my dog up from the veta after work, she had a op so will neet to be watched unfortunately.
  • Like 1
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
