Hmmm nah not just yet just thinking what my problem is.....
I see a como on the up ramp givenn it some hurbs so i decided to downshift from 3rd to 2nd buttt.... then in 2nd i drop clutch revs shoot up to 6ish K then step on it and nothing......? .....? ....? So i take foot off revs drop down to 5k step again and she sings to me till 8k but by then im a fool and im scratching my head why did it do nothing revs hardly went up like if it had no air or fuel.
How long were you at WOT at 6k? Did you notice boost pressure while it was happening?
Did not look at boost but i would say 3sec then i stopped as i did not want to damage anything.
At the moment of intrest it felt like a wipper sniper running out of fuel with the finger on at WOT but maintaining the 6krpm. Ill maybe go of a spin again and set my video camera up on the gauges. All depends on how sleepy I am.
Wouldnt get this with 2 of the big ones [emoji23]
2x gt35
Go for an easy 1000hp, may not see boost till 6k though.
On second thoughts, replace the 26 with a cammed ls7. Have as much power as the -5 turbos and none of the lag or oil issues.
4 hours ago, TiTAN said:
2x gt35
This is true, but u cant beat the sound of a straight six on song ?
  • Like 1
1 hour ago, ElleAli76 said:
Kieran are you going to evo Vs wrx racing tonight ? It's in kwinana
Na, gotta pick my dog up from the veta after work, she had a op so will neet to be watched unfortunately.
  • Like 1
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
