1 hour ago, TiTAN said:
That's a bit like buying a stock car over one with a few boltons.
Clearly you should go for one that's already had the money spent making it better.
its more like not hiring a rent-a-car because it has a pod filter
Is hank away or something?
Also, any brake rotors and pads recommendation? Looking at DBA T3 slotted for fronts and T2 slotted for rears or Dixcel SD/HS (but HS is so expensive).
Pads Project Mu Bspec to go with Dixcel or Red Stuff to go with DBAs
Thoughts?
I have had the red stuff and yellow stuff with the dba slotted rotors.
Reds are a decent low dust pad for Street use. Yellows will take a couple stops before they have enough heat to bite hard, not great on the first few stops in near 0c weather and won't stand up to heavy track use if you have 300+kw, but will do the job if it's mostly stock. you will need something like the blue stuff or just bigger brakes in general if you have a lot of power and want to go hard on the track.
  • Like 1
Thoughts?
My Q1RM pads are great. Would recommend
  • Like 1
Who else is going to the drags Wednesday?
Won't be able to make it (bummer) would like to have another crack at the tree. Show us your reaction times. 11hr day and just got home from bmx. Toasted:-(
Thinking about changing the giant exhaust tip on my car, to a nice sensible twin-tipped muffler.
Anyone have any thoughts on brands, sound, advice?
I just used magnaflow stuff because I got it at cost through work. Does it have a cat in the system? If there is no cat I would definitely go with a reactive rear not a absorptive muffler. I recall seeing a really good looking Lukey muffler tucked away really nice and neat in this thread a while ago?
I honestly don't know, I've never checked as it's one of those things I don't normally care about.
  • Like 1
What rwhp? Does it have a spit dump pipe? Mine had a 3" to 3 1/2" inch when I got it so I just went 3" straight through after the split dump with a 100cell cat skinny long front and fat short rear absorption types. 110kph is about 3000rpm in 5th it planes out reasonsbly quiet but is no cruiser and has nice idle sound. The xr8 is twin 2 1/2" absorptions with 400cell cats and planes out pretty good cruising also and is quiet but meaty at idle. Depends on what you want. So only advice and didn't really answer the question. [emoji16]
The boost psi would be the determing factor from what it needs to push out. I'm only 340rwhp at nearly 18psi and the 3 1/2" fluttered firrrrrrrt pop bang. Doesn't really fart and pop now unless you heel toe the down shifts at high rpm. Pointless owning a skyline without a bit of noise!
  • Like 1
Wheel alignment attempted, works 40k machine doesnt list the r32 or r33. R34 settings used. 2 hours of faffing about and its not much better lol have to attempt it again some other time....
Does it have the hicas or a lockout?
Could take the d-max down if I asked the boss! Lol. Lack of boost night!
Complete lock out, hicas completly removed. Its just irritating that u adjust one thing and it wacks everything out lol
I got 2 sets of front castor arm bushes before my mate Dave measured them to realise they are adjustables off a 34. Show us your actual mechanic! And Frankenstein car!
He aligned it the same day they had the machiene calibrated so is all good now. What do you do for work/job?
Magnaflow would be good :)
  • Like 1
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must me missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
    • @Murray_Calavera iam just considering options 🙂 of course it is very expensive so that why i ask here 🙂  @joshuaho96 I looked at that GCG hybrid(i remember looking at it few weeks before) So this is "that" hybrid where i send them my turbo and they upgrade the inside to Garrett stuff and then they send it back. It cost around 1200-1300 USD which is FAR cheaper than the HKS and it is what iam looking for(i just do not have experience like this...to send something off to "upgrade" ) @tylink720 that is like 150 USD turbo no? 😄 I dont think i have the "ease on my mind" with this kind of turbo. I just put over 7000k USD to "LINK" up my engine...dont want to blow it up with cheap turbo 😄     EDIT: https://www.cj-motor.com/gcg-turbo-charger-for-nissan-rb20det-rb25det-high?srsltid=AfmBOooVeOZ6CZ6r1AIv5m-KPaa6BvudIPJTY8LW78khkd-gQlsaCht9 I looked at this and it seems ok? It is that CGC hybrid and it costs around 1250 USD (with back shipping). Do any of you have experience with this hybrid on NEO turbo? I quickly look thru the forum/web and it seems very good.
    • Echo the awesome sentiment 👍 Definitely a car worth saving. Looking forward to seeing updates as well.
    • Scenic roads, stunning skylines, and Chickos to finish it off! Join SAU NSW as we cruise through the Royal National Park and along Lawrence Hargrave Drive to Figtree! Sunday 26th October 2025 4:30PM Meeting Waterfall Station Parking 5:00PM Cruise Departure Royal National Park > Lawrence Hargrave Dr > Memorial Dr > Sid Parrish Park 6:15PM Arrival at Sid Parrish Park Figtree Meet Location: Waterfall Station Parking Final Destination: Sid Parrish Park RSVP: https://forms.gle/E4s5SiRKQfDdypky8 *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
