Won't be able to make it (bummer) would like to have another crack at the tree. Show us your reaction times. 11hr day and just got home from bmx. Toasted:-(
If nobody is going I might go fishing instead
20 hours ago, TiTAN said:
They look hideous.
It makes for a rear end only a mother could love.
Bah nonsense they are heaps better looking. Nice clean lines. And that trunk hnnnggggggg
this fireplace would wanna throw out some serious heat after 4 days of f*cking around trying to improve it. even just simple tasks are hard when your jammed in the chimney and can barely move around....
plus just copped a falling piece of flue in the head...so ive well and truly had enough
  • Like 1
Maybe he has run away with Elle?
Hahahahahahahaha He dumped me [emoji24][emoji24][emoji24][emoji24] long time ago , I have no running partner now [emoji28]
He's got new chick [emoji213] [emoji8]
  • Like 1
Elle's back!!
Hahahahah not for long [emoji4] Gtg soon - rock band event at work
Tonight [emoji28] and doc appointment @ 4 !
Chat soon guys
P/s -
Who's going tonight ? And let me know when is the next meet up eat and cruise xx
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
