55 minutes ago, t_revz said:
I know the feeling, nothing brightens my day like watching the sunrise while working on some old busted bit of gear that they want miracles preformed on when just last week it was in a graveyard scrap pile, now she is "mint"
At least u r home. I'm in a busted ass camp on the middle of the desert for 2 weeks [emoji23]
Out in the middle of bum fuc##d Egypt. Or my car port.DSC_0194.JPGDSC_0195.JPGtacking the cat into place with a arc welder and 308ss rods
  • Like 1
Jeese. That's a oldie
Yeah could have taken the inverter from work but no need. My pop bought it in 1970 along with a pool table, brand spanker mission brown hq 202 3 on the tree and a massive shed. She runs fully sweet;-) pop and uncle Alf were both boilermakers at the midland workshops and nanna machiened shells there during ww2. Not a single stick or mrrmp just tacked it straight up upside down under the Nissan. Piece of piss with 308 14# rods:-)
  • Like 2
Been up since 0430. My life sux balls
Anyway, who's going to Cars and Coffee on the 2nd July at the plex
If you flicked the switch at 4:30am and it was still dark it would be worse.:-( show us your gas turbine!
I joined this forum under the impression that you lot like to go out with your cars to enjoy them. Oh how wrong was I now that being said what is it that you lot fear the most. A paint chip or someone else enjoying your car after they pry it out of your cold dead hands. Ffs let's get real we have nice cars but don't want to have fun with them or put kms on them. Go Join the vintage club and dust collection. This is what really f**ks me off people having nice cars who refuse to use them what they were intended for.
  • Like 1
    • So I put it to 3bar (43.5psi) while priming. It stays at 43.5~ as I crank shakes slightly. Ive also tried dropping pressure to see if that changes anything. I replaced the fuel dampener because I was troubleshooting the system along with the stock FPR (swapping them one by one to rule them out). But i only got up to changing the dampener and it started running again. Injectors are stock second hand. I did a bench test on both my original ones and the secondhand ones. The second hand injectors I have in the car now spray slightly stronger than my original injectors.
    • I knew Andy from about then, it did some cool stuff. By 2005/2006 era, he also implemented closed loop ignition timing tuning. In 2004 it was pretty cool, being with him when he was doing automated fast self learning tuning!
    • Im No tuner but…. im running a 25det with north of 600wkw at 9000rpm e85 and water meth. G40 1150 on 32psi. Having a real built head will flow a crap ton more power but you being stuck at 7600 won’t be helping at all, throw all the boost you can and nothing will happen. Solid lifter and 9000rpm is the only way,  I have built my motor 3 times, not from engine failure but more along the lines of my failures in not understanding engine parts better, basic phrase to help, “block hold power”  “head make power”
    • What's the fuel pressure while the car is cranking? Curious, why did you replace the fuel damper? What injectors are you using, are they brand new?
    • I think it's terrible value, it should be half that price IMO. And I'm known as someone who will unironically suggest the GTIII-SS on the RB26 if you have very specific requirements. The GCG RB25DET "hybrid turbo" is 1/3rd the cost of this GTIII-RS kit and sounds like it should fit with zero modifications. Talk to Hypergear as well, maybe they can do something that fits your requirements.
