no.
fuel or ignition, fuel cut is the go to default as its softer. ignition cut gives pops and bangs (and on an RB isnt great for the oil pump) and is harder.
powerfc does fuel cut for the limiter, more advanced computers can do either or both as steps (eg kill fuel at 8k and fuel and ignition at 8.5k)
  • Like 1
no.
Why oil pump dont like it ?
Im thinking of detonation as i did hit 66 knock at 7950rpm pop pop pop.
I have dejetro i have map no AFM
The only one for ign cut in PFC is pfc Pro n it has launch control too.
Im intrested in how launch control is done and how much more its helpfull
Because the oil pump drive off the crank gets smacked around like a hammer as the ignition cut limiters are generally faster to cut/resume and this eventually cracks the gear in your oil pump losing oil pressure followed shortly by the rest of your engine and turbo dying.
Launch control depends on the ecu, some are just a 2ndary limiter, some do ignition retard and add fuel to build boost. If you have a gtst. Launch control that builds boost is fairly pointless as it just results in wheel spin.
Full grip baby GT-R style [emoji12]
Then it makes more sense.
But be aware that it's not nice on your gearbox/clutch/drive shafts. Revving the car up to 4k and dropping the clutch isn't nearly as likely to break things as Revving the car up to 4k, building 20psi and then dropping the clutch.
It's really a show off thing or drag racing thing, other than making turbo noises at the lights or in carparks it has no practical Street use.
4k and full boost yummm.
I attempted learning to do smooth launch 7k drop clutch swiftly.
But still smelt clutch now paranoid about clutch life left.
Anything under 7k i bogged down. May -5 turbos not helping
I hit 300 knock once. 91ron fuel
Good times
Our pumps came with a hex type shape that cracks on the corners and it didn't sit fully on the crank on earlier models so the edges get worn making a loose fit.
I fitted a collar to my crank to rectify but mobs like tomei use a spline instead of the hex
  • Like 1
Good times as in rebuild?
Only 1 piston didn't have broken ring lands when I rebuilt but I'm unsure which incident broke them. It was overheated twice. Knocked to 300 once and ran so retarded once that the exhaust manifold snapped,all studs broke, turbo shaft snapped and engine harness melted
But I rebuilt it 3 years after all of these events so it held up well [emoji12]
Wow that a decent effort.
So did you do a spastic rebuild or a normal one.
Same crank, forged JE pistons, spent a heap on port/polish and modifying the head. Tomei cams,springs,exh gear. New turbo and all the associated supporting bits.
Best case should do about 450hp at treads on 98 or into the mid 500's on e85. Hopefully get it going within a week. Needs a new alarm system
Is it worth the money on the head. Coz that the area i 1st want to mod.
It's not one of the things you need to bother with at the power level -5 will give you. Small duration high lift cams are a better spend (~260 deg ~10mm)
  • Like 1
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
