56 minutes ago, t_revz said:
Any winery recommendations for the swan valley? Staying there tomorrow and Friday night
They are mostly the same as Margaret River....
Mandoon Estate is a pretty nice estate.
Ugly Duckling isn't too bad.
Lamont's used to be very good (2013-2015) but lately their wines have been disappointing. Not sure about this years, last I was there was early 2016.
Edgecombe Brothers does pretty decent Muscat if you're into those...you can drop by for ice cream and muscat at the restaurant/cafe...
  • Like 1
