Also got a photo of each spark plug
My opinion is plug photos are irrelevant except for checking last RPM.
ie- your plugs look richer on 3+4 but that could be just at idle.
I've pulled plugs after idling,cruising and on the highway turning engine off at 6k WOT and they look very different.
What plugs did you fit afterwards? Coppers or iridium?
Nah just did the comp n plug check
Yeah i do let it run a bit before i park up slow drive up the hill n cool down probably a good 2mins worth
Thay r PFR6A11 Laser Platinum Plug
Maybe 3, 4 could do a change coz of platinum worn a bit on edge but there not much KM on it.
Don't waste money on platinums.
Throw em in the bin
Sub 400hp I'd say bcpr6es coppers
Above 400 run 7's
Went to the city stage of the rally today. Way more skylines running in the mornings classic car section. Had some 32 33 34 gt-r and gt-st's Heaps better than the Malaga and Whiteman park stages. 5 hrs in very mild sun and strong wind. Curse of the ranga, unbelievably got burnt.
know them feels...
thinking of the sun gets me burnt
  • Like 1
On 8/12/2017 at 0:48 PM, pol1on1 said:
Yer i used deconjestion spray that solves bit of it but xray shows that i had a defomed canal that worked as a 1 way valve basically not allowing suction to top sinus (above eye) when landing which made alot of pain the worse I've is numb jaw striking pain down neck and numb collarbone with eye feeling like exploding that was every second swing landing for me.@manne I've read you have some similar issues
Yeah dude, Three weeks and i'm feeling much better but there is still a little bit of pressure around the nose/eyes that flares up from time to time.
I'm currently using a Sinus cleaner thing, it's a bottle with a thing you stuck up your nose and squeeze, and it flushes them all out.
Agree with you though, the Pain is UNREAL, I was knocked out for a good week, sleeping 20 hours a day, and then somehow, my chest became all messed up too.
Steroids, Sprays, Antibiotics and 3 and a half weeks, but i'm still not better.
know them feels...
Panicked when we got to Toodyay. Jack was like there is smoke coming out from under the bonnet. Wtf. Bonnet was a bit hot with no blanket underneath it was steaming the rain over the turbo off the top of the bonnet. Was just running up the hills in 5th and loading it up on the way there with the boost controller off. Used 4th for the hills on the way home at 14psi no probs. Different animal to the 4,9 5.8 5.0 and 5.4 lesson learned. Bugger all torque at low revs. think I will get rid of the 200cell catco oval and go to the venom 100cell with the 5" substrate. Tuning is beyond my nuts and bolts ability. Any thoughts? We ran sweet to and from Albany and did 1000kms pushing it hard. The original 100 cell metal cat copped a massive smash over a trainline bump at full speed the substrate came loose and flew into the exhaust melted and killed it and we popped a intercooler hose because it blocked the exhaust.(the weekest link) have swaged pressure tested and redone all the tubes and hoses with a intercooler flush. Would I need to retune between replacing the cats? Any advise would be appreciated. Thanks.
I will come Eli!
know them feels...
I will come Eli!
Don't get me wrong she's running and pulling hard at 18psi still. All temps and pressures are normal. Just seems to have lost a bit at say 6000 to 7000 under full load? Trevs? Kizza?
Hows weekend for Everyone ? Next week Saturday - Any idea where we going to meet up before head Down to barbagello ? Cruisinnnnnn All
Together from joondalup ?
Whos going ?
Yeah 84 and I will be there, my mate wants to come with so I'm gonna be in the Prado
    • Nope.    Grab a varex and turn it down as you get close to home, win win?
    • So, I've had my V36 for about a month now and have already copped an "excessive exhaust noise" notification from QLD TMR, reported by someone in my local area. It's a twin as per the original, and can have a bit of a throaty note to it when idling cold 😄 and if I do get up it a bit, it can be noisy, but it did pass a roadworthy inspection before sale, so.... ... but in the interest of being a good neighbour, I do want to quieten it down a bit. Is anyone here running a quiet aftermarket cat-back on their V36 or 370Z? And the big, bold question: does an aftermarket cat-back really make much of a performance difference on these cars?
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
