45 minutes ago, Beyond Blue R33 said:
DSC_0298.JPGDSC_0299.JPGthe wife me and my dad built that s.o.b. 20 years ago. Hip jointing and angles with circular saw and mitre box with Tennant saw. Skewed nails with no nail gun. Hammer and nail punches. Ladders in sand and rapid set all the posts in. Painted all the pine with rollers in the car port before dad engineered it. Leanne and I were his lackeys, that's what makes it a home and why I'm reluctant to ever sell;-) we were fully broke at the time and dad bought all the sheeting for us as a Christmas gift:-) boxing day dad and I on ladders fitting the sheets. Our family home:-)
Nice job, ud pay big money for that these days
4 hours ago, Beyond Blue R33 said:
Yep abs ebd asm trc 70kmph on tonkin and roe. Had a m5 in front of me today slowed down to 60 when it rained. Madness!
I took to the inside lane at 110 lol why do people not use the inside lane?
DSC_0298.JPG.0fcec10eecf9bc9c5684db12fabd9a52.JPGDSC_0299.JPG.7b6a84d0f167ef35f1ef65424ffc79c0.JPGthe wife me and my dad built that s.o.b. 20 years ago. Hip jointing and angles with circular saw and mitre box with Tennant saw. Skewed nails with no nail gun. Hammer and nail punches. Ladders in sand and rapid set all the posts in. Painted all the pine with rollers in the car port before dad engineered it. Leanne and I were his lackeys, that's what makes it a home and why I'm reluctant to ever sell;-) we were fully broke at the time and dad bought all the sheeting for us as a Christmas gift:-) boxing day dad and I on ladders fitting the sheets. Our family home:-)
Nice work looks good !
Shity weather now for skyline drives so im currently building my entrance decking using ekodeck apparently never needs oiling coz its 45% bamboo 45% plastic. But bloody hell its expensive
  • Like 1
Looking good. I'm up to the 3rd tin of oil for the gazebo at $70 bucks a pop so will pay for its self in the end.
  • Like 1
Gazebo. Or as I like to call it the white elephant. Wife had too have it. Brand new, never been used, no joy riders low ballers or time wasters. DSC_0315.JPGDSC_0317.JPGDSC_0316.JPGchews more oil than a ls1:-o
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.   EDIT:  Not my channel but i saw this and i know that is what i want (and i have exactly this)
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
