Got my new head unit fitted today. Ran the cables down the back for 2 reverse cameras but ran out of time to fit them. Everything works well but it doesn't pick up the Bluetooth obd reader. Not sure if it's faulty. Plug obd into missus car and it saw it for a second then couldn't find again.
Finally a relief to have music to listen to while going to work
  • Like 4
Bluetooth obd and iPhones don't seem to talk well I use a wifi one it works much better
Whats wrong with the music of a straight 6?
2 hours ago, t_revz said:
They are both Bluetooth. It detects my phone but iPhones won't detect this type of unit
Shitty iphones.... having issues with the bmws not liking iphones, its the iphone software at fault. Bmw are working with apple to try fix it....
  • Like 1
The Head unit I want for my car is $999 from Pioneer...and JB's don't sell it so I can't even staff price it. Everything is on hold at the moment anyway.
Maybe I can return the favour, @shoey84 now works at Autobarn and they sell Pioneer, I can get it at staff from them for you!
If they have it, wouldn't mind  a quote on the "AVH-Z7050BT" Not planning on buying ASAP, but it's on the list.
https://www.pioneer.com.au/shop/car/avh-z7050bt/
And Justice for tevs...
Got fibre to node nbn connected today with a new router. Hooked it all up and it actually worked? Amazing for telstra. 49.01 Mbps download 31.82 Mbps upload. Madness. Thanks Kevin 747. Got my t.v., ps3, ps4, t-box and foxtel hooked up to the lan running a rj8 cable through the roof down to a powered splitter. All devices are running a similar speed. All the wife and kids systems are running Wi-Fi and getting 20mbps down 9mbps up. Insane!
  • Like 1
Coilovers wont help tramping, too stiff a coilover and low profile tyres dont mix. More side wall = better traction but reduces lateral loading. Less side wall = worse traction but better lateral loading. Then u have to think contact patch, right width for right power.
I went for 245/17/40's to give it a bit more side wall. The xr8 has 245/19/30's. The tramping goes away at 28psi but comes back around 32psi. The contact patch looks horrible at 28psi and will kill the inside of the tyres. If I go up to 36psi it's just full wheel spin? The Bridgestone guy reconds to run 40psi in the falcon and it loves it. Steers spins and squats pretty nice. My mate Dave is coming over Saturday so I'll get him to take it for a spin and see what he thinks. His mustang just squats and fries at any speed in second. Bombed 351 Windsor, manualised c10, 9" with 3:95s. No power anything except for the motor;-)
Oh i hate apple so much only works with the same devices.
Android Microsoft linux are all happy piece of equipment
  • Like 1
My wife has a windows 8 phone. I fitted a Sony Bluetooth head unit to the falcon with a mic up behind the front sun visor. Bought a kit of eBay. It still utilises all the steering wheel controls and only uses the Sony as a replacement head control unit. Works perfect with the phone. Contacts, calls, streaming, etc. We replaced 2 x ford 6 x disc units from the factory and it kept on eating discs and malfunctioning. It's Been in for over a year and no probs. She loves it. Ford has a reasonable factory system with a 8" sub in the rear parcel shelf and splits in the front. Happy times. Made me look good for once!
  • Like 1
The Sony in the Ford recognises my experia instantly on entry in drive mode so as soon as I get in it connects automatically. The Bluetooth unit in the d-max does the same. I listen to a old time radio app to and from work which I download the stories at home from. CBS radio mystery theatre. Told you guys I was fully old:-(
  • Like 1
The old alpine head unit in the Nissan has a dodgy touch screen so I bought the remote off ebay for $15.00 is cool to listen to DVDs on it. You know because I never watch the screen while driving. Opeth, iron maiden, Metallica etc. Dolby dig and dts.
  • Like 1
Wtf. Chip on her shoulder, my last name is grimshaw. Tracy grimshaw arrested for causing a massive accident by cutting the brake lines on a car someone has sunk 30 grand into like she is a mob boss. In cahoots with the guy from a current affair who was arrested for? You know what. Scum
Ranga arrested for running down Tracy grimshaw in epe ute. Apparently he was just trying to ensure engine protection equipment :'(
    • Did you pay with a credit card? I'd be putting a charge back through then finding a new sparky to sort it out.
    • If you mean the alarm immobiliser; theyre internal to the alarm itself which makes that difficult; I couldnt even see where he put it; its not in the same place as last time; but with all black wiring it might be very challenging to trace  I had someone turn the key for me as I know it only primes for a couple of seconds As my post above; I am getting no voltage to the pump at all; but I am testing continuity of the power line (SB) from the pump plug to the relay fine. As well as the negative from the pump plug to a 12V constant.    Yeah; he blammed the no start on a bad battery; said I needed to get a new battery and it'll start. Turns out the battery drained because the tail lights had been on for half the day during the install (the rubber cushion on the brake switch gave out while he was testing it as I have a picture of the car from that morning with the tail lights off..i've replaced that). The battery was turning over the engine just fine for a long time; but got low since lights were draining it so it was too low to test a start after he finished. I bought a new one on his advice...$250 wasted. My original battery charged up just fine and is healthy.    It was running perfectly fine when I messed up the old alarm (programmed out the remotes). He couldnt start it after removing the old alarm; my assumption is that when he unhooked it; he didnt bridge the circuit back when trying to start it. Its always been perfectly fine. The ECU swap and pump were 2 years ago. It's never missed a beat in that time.
    • This is a big issue for me without the diff. I just have zero drive from the passenger side when drivers side has no traction. Bec's parents place has a crazy steep driveway with odd camber and I have never been able to get up. My bro-in-law's 130i with an (unknown brand) LSD gets up fine as does their dad's Hiace. My car stays at the bottom. We have other odd camber roads around here as we're elevated a bit and if it's raining I can get totally stuck around some hairpins.
    • Yeah, I am super excited for this.
    • Was the car running before he touched the car?
