Mate you would be shocked (its horrible) if you saw my work tonight, fkn dogs been chewing on the doors for a while so I had to sort it out today when I saw one in the garage after work.
Not too bad for a paper pusher in a West Perth office!
By day Martin the paper pusher by night under his secret alias Shoey the sheety. I thought it looked pretty good ;-)
  • Like 2
34 minutes ago, R33kizza said:
I think you got issues.....
It's a newish battery too. Bought it about 8months ago. Got the cat jumped and drove it home (another 30minutes) the battery wasn't charging at all. On Tonkin if I flicked my lights on my electrics would turn off, even the stereo.
Got her home. Shut the engine off and immediately tried to start it. Nothing. Completely flat .
  • Like 1
Charge up the battery check the voltage with a multi meter it should be about 13ish volts at full charge. Put the battery in the car start it and with it running it should be about 14.2 to 14.4v this will prove if the alternator I's charging the battery. If it has a external voltage regulator you will only need to replace the regulator. If it's built in new alternator? Cheapie multimeter is only about $30. What cca is the battery? Check the water level and make sure the cells are covered with distilled water.
  • Like 1
Does the battery light on the dash come on?
  • Like 1
DSC_0120(1).JPGI've got a little tacker here I can charge up for a spare if you want it? Has 10mm or 3/8 terminals so no good for our cars at home. Only a year old free:-) I recall you had a monster under the bonnet. Does it still have the battery in the boot? Maybe a dual battery system?
  • Like 1
DSC_0120(1).JPG.f5f30fe11e8e050c32e5a76cf64df835.JPGI've got a little tacker here I can charge up for a spare if you want it? Has 10mm or 3/8 terminals so no good for our cars at home. Only a year old free:-) I recall you had a monster under the bonnet. Does it still have the battery in the boot? Maybe a dual battery system?
The car will run with no accessories for ages if the alternator isn't charging the battery. It's the accessories that will kill it. Stereo lights a/c etc.
  • Like 1
You've got a charge issue mate and probably battery is fine.
Does batt light come on with key on them go off when started? Is the fan belt tight? Sometimes the belt can slip without making much noise.
  • Like 2
External regulator?
The 70's are over mate!! Welcome to the 21st century :)
  • Like 1
Would have to be insanely loose to not turn the water pump and alternator?
It could be the battery, car wouldnt run if the alternator wasnt charging. Batterys can collapse at any time. Is it hooked up to a trickle charger at all? Worse things in the world for batterys, slowly cook them to death....
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
