I want something like this ! Remembered I’ve been talking about it ?
Mark from C-red & Phil’s work efforts [emoji28]
Oh by the way the calipers aren’t ready :)
Hopefully the legamax exhaust arrived this week too [emoji7]
  • Like 1
It’s definitely a girl car now bitches IMG_1069.thumb.jpg.a4ddf7fa55f98af0579145ace64f280c.jpgIMG_1072.thumb.jpg.0da05c33c64b04de6a871c239049de97.jpg
Oh by the way the calipers aren’t ready [emoji4]
Nice [emoji1303]
  • Like 2
Red shoes then:-) life of the party!
Killed the beast on Sunday. 3/4 at 7000. Clutch on the floor. Whoops. Bled the slave and master no good. Assuming thrust bearing not releasing. Bent/ snapped fork or collapsed pressure plate spring? Any thoughts anyone?
Aids
  • Like 1
5 hours ago, shoey85 said:
Think ours can stay manky looking no point painting stock yucko calipers
What shoes go with purple or blue pants? A question for the wife definitely :-) I reckon black.
Gold goes with blue, subies taught us that! Bronze or gold on purple
  • Like 1
On a more serious note lol, stick it gear and try and push it. If it moves u kniw its clutch for sure. Chances are its a dead slave or master
  • Like 1
Broken pivot ball
  • Like 1
Elsie, did you look at amayama for your upper arms?
I havent Corey , But definately will look up for one and Also the other options is to wait for Lochy :)
Is it wise to use a second hand bushes?
  • Like 1
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
