9 hours ago, ElleAli76 said:
I havent Corey , But definately will look up for one and Also the other options is to wait for Lochy :)
Is it wise to use a second hand bushes?
No i would not advise it. You don't know how it has been treated before, if it has been affected by chemicals etc.
  • Like 1
8 hours ago, TiTAN said:
If it was a porsche, green brakes indicate it's a hybrid. Red has regular iron disks and yellow for carbon ceramic.
That's interesting. Mine is kind of a hybrid, 26, rwd, PPG, sedan etc etc
I havent Corey , But definately will look up for one and Also the other options is to wait for Lochy [emoji4]
High performance new Nissan gt-r. Keep it that way.
  • Like 1
Your gonna pull all the boys with them! I reckon Hanky’s gonna get wet for them [emoji6]
???? it’s good colour huh !
Can’t wait to see her with the new exhaust ! Hurry up galvesport!
  • Like 2
Fairly bright colour. My brembo stickers came in today also, waiting on the painter to have spare time to get all my bits done
It’s called hot pink and it’s a lil bit bright [emoji28]
Oh well [emoji28]
Surprisingly the calipers took a bit longer than the wheels !
Now how long would it take to have the exhaust fitted ?
  • Like 1
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
    • Yeah - I mean, go the other way. Smaller range. Not larger.
