Yea busy with work and then studying for another certification that I just started. Also went through a breakup (5 yrs) among other crap that is going on haha!
Don’t be sad Lochy is back , available and his everyone’s bitches ( Favorite) [emoji13][emoji87]
  • Like 1
3 hours ago, shoey85 said:
Hey Colin it’s been a while have you been busy?
We should Organise a cruise!
2 hours ago, ElleAli76 said:
When are we catching up again eat eat eat and meet ? emoji87.png?
16th or 17th of December work for anyone or perhaps the weekend before?
  • Like 1
Looks like the skyline womt be bk on the streets for a fair few years.... my insurance on my 1.6 firsta has gone up to 850bucks since i added the claim on [emoji52]
Feck, can’t wait to see mine [emoji30]
  • Like 1
House, life, car, hospital, businesses, superannuation, mortgage, they are f**king assurances not insurances. I often wonder if I'd saved that money over the last 25yrs how much I'd have saved up to pay for any emergency. Would have to be at least $100,000. Kent's.
  • Like 1
Let’s be honest would you really have saved it?
  • Like 1
Nope that's why I was wondering. Dave pays $450pr annum on $40,000 for mustang. I'm paying $800pr annum on 15.000 skyline? Both shannons go figure?
The little blue skip bin that could. Shovelling money into Nissan's little beast. I think I can I know I can:-o
  • Like 1
80k 4x4 is only 800pa, 16500 Skyline also 800pa [emoji848]
21 minutes ago, shoey85 said:
Skylines are all imports, high powered moat of the time and classed as a high risk vehicle... hence shannons is the only known insurer that i know of who will insure them
  • Like 1
    • The attached document is fine. I just downloaded & opened it.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
