15 minutes ago, R33kizza said:
Skylines are all imports, high powered moat of the time and classed as a high risk vehicle... hence shannons is the only known insurer that i know of who will insure them
SGIO insured mine no worries.
  • Like 2
Way moar dangerous than a bombed 351 Windsor manualised shift kit c10 with high stall and 3:95 9" lsd I think not. Goes hard might stop down the road eventually.
Yeah buddy! Im asuming u know how to use the 3rd pedal ur about to install??? [emoji23][emoji23][emoji23][emoji23][emoji23][emoji23][emoji23][emoji23]
Haha yeah man both wife and I have manual license and prefer a manual, probably get Marc at C-Red to do the install
  • Like 2
  • Like 1
Shazza loves that shit. Dazza can afford it.
  • Like 1
2 hours ago, Beyond Blue R33 said:
10 hours ago, shoey85 said:
House, life, car, hospital, businesses, superannuation, mortgage, they are f**king assurances not insurances. I often wonder if I'd saved that money over the last 25yrs how much I'd have saved up to pay for any emergency. Would have to be at least $100,000. Kent's.
i dont insure my skyline as it barely gets driven. has saved me a fortune in the past 8 years
  • Like 3
2 hours ago, shoey85 said:
Let’s be honest would you really have saved it?
Nope that's why I was wondering. Dave pays $450pr annum on $40,000 for mustang. I'm paying $800pr annum on 15.000 skyline? Both shannons go figure?
cos booooooosstt
  • Like 1
but skylines can jump opening bridges and drive under semi trailers. plus they all have 2 of the big ones in the back seat along with all the other overnight parts from japan
  • Like 4
1 hour ago, t_revz said:
yeh this does happen... my passenger door once stopped 2 inches from a pole.
0psi to full boost in the blink of an eye haha
Its amazing how cast it can spool up with no traction lol
  • Haha 1
Honda civics are the ones that can drive under trailers, eclipses get 2 of the big ones and supras are the ones that get overnight parts from Japan.
  • Like 1
I like a man who has spent WAY too much time watching crap movies.
Netflix and chill?
    • Something I meant to say when we were chatting the other night about having an open trailer floor being great to work on a car, but you've never used the feature... It's a great place to park a car after doing suspension component changes, and do the tightening of all the bushes with the car sitting at full ride height. Especially when you don't have a 4 post hoist!
    • That is way more science than even I would use. I just eyeball it, not even accounting for the non-verticality of the tape measure when held on the lip and the centre at the same time. +/- 2mm is good enough for the girls I go out with.
    • So, before putting them in I need to understand the stock ride height. This is how I measured it: First, check the diameter of the wheel's centre cap, it was 52mm. Then put a piece of masking tape approximately across the centre and measure 27mm (half) from at least 3 sides to get a reasonable idea of the centre of the wheel cap. Mark that with a horizontal line as one measuring point. Then, directly above the wheel on the guard, put another piece of masking tape in approximately the centre. Use a string line to find out the point on the guard above the centre of the wheel cap and mark that. Then it is simple, just a tape measure to check the distance from centre of the wheel to the centre of the guard. Final results where  LF: 381mm RF: 379mm LR: 401mm RR: 400mm Pretty even considering they are 120,000klm old factory springs, lets call that 380 front and 400 rear.
    • So....knowing that I have a problem with power steering temps on track and another Wakefield day booked in next Friday, I've done the obvious thing They are very reasonably priced at $1650, considering they are a big monotube shock, double height adjustable (don't have to change pre-load to change ride height), one way adjustable damping and standard sized and customisable springs if you want something other than what comes with them. They come with 9kg/mm front and 4.5kg/mm front and I went with that as a starting point because I'll add adjustable sway bars too https://justjap.com/products/bc-racing-coilover-kit-ds-ds-infiniti-q50-v37-14-current#description Unfortunately they didn't come with rear strut tops so I've re-used the factory ones which was a bit of a pain. Also, the adjuster for the rear shock will be an absolute nightmare to get at, and while there are extensions in the kit I can't see any way you can actually attach or use them
    • I also had 2 bulbs blow at once, years ago in the stagea. made for a fun drive home. The issue was the voltage regulator had failed in the alternator and it was giving 15+ volts. Really, I was lucky all that was fried were the headlight bulbs. So, I'd suggest you check the voltage across your battery terminals with the car running and warmed up. Yes, you will need a multimeter to do so, sorry.
