It was one of the first films I had on DVD.
Will there be cake?
Metallica cunning stunts on ps2. Couldn't believe the quality through a Scart connector and 68cm t.v. With analouge Yamaha amp.
You need the rainbow licka sticka first.
If it doesn't stick the first time you just need to lick the back of it over and over until your jaw locks up. Then boom fully sticky fully qualified. Might take 4yrs.
Suppose there is no need to explain to a auto electrician to the stars:-o
you'll need to speak slowly for me
ohai
what do you know about getting custom spokes done? Got a woof in the front rim, was going to motard it anyway, so was thinking of slotting a 17" hoop on the front. Problem is, I need to keep the speedo drive in the front hub, so swapping a YZ rim is not an option
ohai
So you have a 19” rim and wanna fit a 17” rim with spokes to suit?
Nah, 21" front hoop to a 17" hoop
Brake clearance etc is already checked, and rim sourcing is easy, just hit a wall when trying to find spokes. I am thinking they will have to be made? Or do you know if mine can be shortened and rethreaded?
Why wouldn’t 17” standard spokes fit?
Because angle out of hub is too far in compared to standard?
If u can find someone who already does the wheels or a model of bike that already has motard wheels the u could buy the spokes from a dealer
standard 17" hub has no speedo drive, so its about half the diameter and about 2/3 the width.
We think very similar
Unfortunately, 17" rims on XT's are usually acheived with an entire YZ460  front end swap as you get upside down forks of the correct length, a triple tree that bolts straight on (and has steering damper options up the wahzoo) and a 17" rim
What you dont get, is a speedo drive. This is usually sorted with a $500 electronic dash, but its actually a stickerable offense to do this, and I dont have the coin for the dash or a crumpled YZ anyway.
Plus, speccy upside down forks and a front disc setup designed for dirt, isnt really going to match the rat rod/street scrambler vibe I am going for
Im a motorcycle technician by trade. If u dont need the bike ur best bet would be to buy a 17" wheel then find a wherl builder to swap the hubs. 17" fitment with ur original hub assebly.
  • Like 1
Yep, I am hearing you, but I am looking down the barrel of spinal fusion, and am off the bike for 6 months so I am really needing things to do to it, (because if I dont pull it apart I am going to end up trying to ride it, plus) and need shit to keep me busy
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
