No much worse, an Oil & Gas company that never stops production where every day lost is over $1m in revenue
Got the 3 days between for 10 days off. Have beaten the 2nd week of Jan deadline by 3 weeks yeah. Quoted 120hrs on job for Jan and got the job. Quoted 260hrs for another job in Jan and got the job. :-o hope the couch can handle 10 days of my fat arse on it. Do you want ham in those toasties, ham and salad roll, ham and ham with ham on the side?
  • Like 2
10 hours ago, turboedsloth said:
Going back to doodling Dale?
am already back doodling, thank fk
Still trying to get over the fact that they replaced the automatic espresso machine for a fkn pod thing
A FKN POD THING, PEOPLE!!!! THE REVOLUTION WILL NOT BE TELEVISED!!!!!!!
  • Like 1
We almost did that at work too!
  • Like 1
All modified skylines have coffee pod filter. Froths up the oil into the catch can and pcv valve for a sweet fuming blend of 7.5/35w. need a fmic for the one at home. Has been a bit sluggish lately?
  • Like 1
coffee pods are the devil. They have the WORST coffee in them - the one at work actually trys and uses the fact that it has robusta beans in it as a positive :cry:
Plus, the stupid amount of packaging waste they make is one of the things the next generation is gonna be pretty pissed about, and I cant say I blame them
Green pods are people.
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
    • Shimmed or shimless, still solid, no hydraulic pump up stuff.
