9 hours ago, Manne said:
When Thy has no Money.
Actually drives pretty good for an N/A Auto.
If I could find a roller I could put the 20 brap in one...
  • Like 2
Hills run would be sick day time obviously
Finished the big jobs today, finished work at 2:30pm. So for the 12 weeks o.t. With handshakes and top efforts all round got my worst x-mas bonus in the last 10yrs. The lead balloon went down when I interrupted the times are tight speech with "I thought last year's bonus was f**king shit, thanks" I was promptly reminded lots of people don't get bonuses. Which was met with a casual shrug of the shoulders.
  • Like 1
App no longer working at all 4 me keeps saying networking error (android) on 4g 3g or wifi all the same
Yeah Dean same thing. Have to go back to events page then back to wasteland for updates. Refresh doesn't work.
I had this a while ago. Much to everyone's delight. Uninstalled then re installed, came good but dont get any notifications.
my xmas bonus was being asked to come back on the 2nd instead of the 8th........
ahh the life of the scumbag mercenary contractor, how I have missed you.
Doc has laid down the law that I cant get back on the bike till march, so I'm now getting full on planning for some mods, looking for opinions.on direction
flat track / rat racer
street scrambler
or super motard
thoughts?
01.jpg&key=72f68c476db4e391d7a695be159d6aaf4b03c9121ce37f7ae802c9ece5a0ba6a
street scrambler
a7d552e1562733cbd548e9a76627ad83.jpg&key=ecc28356e4160e961950450d6f8bc0e5ff73227f6055a2f8f411ff9a434824ff
or super motard
a87da3efdde383267a7c21b157470137.jpg&key=c449d6a03ae32ce1bed76d04d44ba42c2f796e9e6cca5edaa02516c688fea7c9
thoughts?
Never go super retard but the street scrambler looks the goods
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
